Front Defroster Suddenly Ticks
l008com
1,030
Massachusetts
My Christmas present this year is a broken defroster. When I try to put my front windsheild on defrost, it just started doing this:
What do you make of that?
If I had to guess, I would say a broken fan box and the fix is to fully take the whole dash apart to replace some $3 part?
Please oh PLEASE tell me I'm wrong!
I don't think it ever stops or ever start blowing the bulk of the air out the front defroster. I don't use the front defroster very often, I generally keep the HVAC on auto or on vent & floor combo. Only when theres actually nice on the front window, do I switch it over.
Reactions: movietvet
Depending on if you have manual controls or automatic controls, I did not watch the video, you can go to you tube and watch at least 3 videos, of each kind, for doing a reset on the heating-a/c system. I say 3 of each because there are some flakes out there that do not know how to communicate to other people. A friend of mine, had a manual control system and had some clicking noises and I did a reset and has worked fine for 8 months now.
I just listened to the noises. That is louooodah! Metal on metal. Try the reset and see what happens.
I don't think its quite as loud in person as it sounds in the video. The phone was closer to the dash when I recorded the audio, than the camera was when i took those random pictures.
In person it does not sound like a metal on metal sound, it definitely sounds like plastic. But still pretty hard for a plastic bang
  • Wow
Yep, try the reset but I'm putting money on the actuator being DOA. Classic symptom.
Yep. First thought is always the actuator but I was surprised when the reset took care of my friend's 2005 Tahoe with manual controls.
So I've been ignoring this all winter but time to revisit and fix.
Here's what I learned. Its actually clicking any time I try to take it OUT of dash-vent mode. Floor and vent is fine, vent only is fine. Any setting with no vent, clicks non stop. INCLUDING shutting the system off entirely!
I did not try any fuse pulling. It was a super cold winter so like I said, I just ignored it. Is it still worth trying that or do the symptoms indicate a definite hardware problem?
I'll probably have time to try the reset process Friday. If it is a hardware problem, what would it be exactly? And how hard is it going to be to fix it?
Definitely an actuator, likely the floor/dash vent one. If it's clicking, a reset is not likely to fix it but you can try. If it does, it won't be permanent.
Ok update time. I FINALLY got around to doing the reset. There were 4 HVAC fuses and I yanked them all, checked my tire pressure all around, then put them back in.
Unfortunately, things are much worse now :Banghead:
It now clicks for a minute or two straight, every single time I turn on the truck.
So, actuator it is? How many actuators are there? What is ACTUALLY happening/failing here? Is this something I can fix by removing the center console but NOT removing the whole dash, hopefully?
  • Wow
There are 5 actuators:
Try each control individually. For the mode, go from defrost to dash vents for the defrost actuator, then from dash to floor for the floor/dash actuator, then each side temp for those two. Then try the recirc. Hopefully that one is fine as it does require dash removal. Pass side temp actuator requires some cutting of a dash brace located right in front of it.
Personally, I would begin by replacing BOTH the MODE and the DEFROST actuators. These are the two that control where the airflow goes AND they are the easiest to do. They are right next to each other on the drivers side above the area of the accelerator pedal. On my 2002 after the lower dash/footwell covers are dropped there is one plastic air duct that needs to come out to get good access to them.
It occurs to me that if these are THAT easy to get to, I can probably just put my hand on them while i turn on the truck and feel which, if any of them, are the ones ticking. Hopefully I have time for this soon because its incredibly annoying.
If you have a mechanics stethoscope, use it. If not, get one. I use mine all the time.
So switching between floor and vent doesn't work. The defrost comes on and off when its supposed to. I'm going to turn recirc on and off right now but based on EVERYTHING, seems like the floor/vent one is the problem. Which I guess I could have also inferred from the initial symptoms too. Runs fine on floor. Clicks any time you try to change it off floor including shutting the system off.
So the other post has a diagram of the actuators:
The thing that makes me nervous still is that while the malfunction strongly points to the floor/dash actuator, if i move my head around my dash while its clicking, it really sounds like its coming from the area where the recirculate actuator is. But this is also the first broken actuator I've ever listened to, so I don't really know how its supposed to sound when each different one is broken.
Also, regarding the diagram, they list the part number for "Airflow Mode Actuator", but the diagram shows a "Floor/Dash Vent Mode Actuator", are those the same part? So if that is the one thats broken, those are the part numbers?
Also at this point, is the easiest way to confirm 100%, just go get under there and unplug the dash floor actuator, then turn on the truck and see if it still clicks?
Jesus the ads on this site are getting out of hand. In both grossness and quantity that can even grind a fast computer to a halt.
ANYWAY, ok so heres the deal. Never air out of vent, always air out of floor. Changing between the two does nothing. Which sure sounds like the floor/vent actuator.
BUT
Also when I hit recirc, it, flashes for a few seconds and then goes out.
Which suggests both, but the odds of both failing are once are low enough that I doubt I have two that are bad.
BUT
Do the one and will likely be fixed.
Are you aware of what the recirc actually does??
The sole action of the recirc is to allow air from outside the vehicle to be drawn in or not. It has absolutely zippety-do-dah to do with where the air blows out.
Exactly why, with recirc on, the a/c blows colder. Is reusing the same interior air.
Yeah, the recirc has nothing to do with the vent, yet they both seem to be broken, which is the dilema.
If the recirc actuator is broken, you're in for a world of pain.
I would replace the mode (floor/vent) actuator first, reset/relearn it, then see if the recirc is also busted.
I recently had to repair the recirc actuator (I didn't replace it, I repaired it by taking it apart and installing roll pins, documented elsewhere here). Here in Arizona it's almost a requirement to have it working. Even after reading up on the procedure and having head knowledge, it was still a major ordeal. It took me nearly 2 days to remove and replace the dash, and I'm retired with little to do most the time. My only advantage is that I'm a small guy and pretty wiry, although at 68 years not so much any more. If one can live without the recirc it's my advice to leave it, unless you're just bored out of your skull, which you will be (out of your skull) afterwards.
Ok how did you get this kind of access? I took all of my under-dash plastics off and I can't see anything? Its like I have no access at all, even these easy two actuators seem buried up in there. I'm heading to youtube now but if you have any tips let me know.
  • Wow
Update!
I pulled half of my dash apart, including removing the radio. And I was able to determine which actuator is clicking....
Maybe.
I Mean I got hands on the clicking actuator, and I unplugged it and started up to confirm that it IS the problem actuator.
But looking at the diagram, I'm still not sure which one I was touching.
I'm not sure if it was the floor/dash, the drefrost or the driver's temp.
Is my only option at this point to yank it and read its part number?
I'm not going to do that now, I'm just going to leave everything as is and hopefully tackle this next week.
Also, is the "Floor/Dash" actuator with the red arrow, the same as the "Airflow Mode Actuator" in blue? I assume thats the same part but they really should have labeled them the same. And when I look up the part number on NAPA, it has yet another name lol.
So I guess my question is, is there an easy way to definitively confirm which one it is? I had to lay on my back and reach up through the bundles of wire to even get it so I'm not sure I can even take a decent picture of it, but I'll try.
"I Mean I got hands on the clicking actuator, and I unplugged it and started up to confirm that it IS the problem actuator."
How do you know it was the clicking actuator, if you unplugged it BEFORE you started up? It would not be clicking if the key/engine is not on/started. You unplugged first and then started. If it always clicked and you unplugged it and then started and there was no clicking, the correct actuator is the UNPLUGGED one.
What I am trying to say is.....if you unplugged it and you can see in the pic the locations, you should be able to feel to find the correct actuator.
I learned a long time ago, that as a tech, I have eyes in my finger tips.
In addition to putting my hands on it while it was clicking, confirming it was definitely the one doing the clicking, I unplugged it with the truck off, then started it up, and no click. It is currently clicking for a minute or so solid, every single time I start up the truck. Except now since unplugging it.
Here's the best photo I could get, which turns out might be good enough!
I zoomed and distorted the photo until I was able to make out the part number. It doesn't match any of the numbers on the previously-linked to actuator part number diagram.
That number (52411434) does not come up on a rockauto search or a napa search. But when I GOOGLE it, I get a ton of actuator matches.
Although they all call the part something different so I guess I'm still not 100% sure which actuator this is :D Can anyone confirm with certainty that this is the "Floor/Dash Vent Mode Actuator" ?
  • Wow
You have an "X" on one and a circle on the other. I can only assume that the circled one is the one you are talking about, correct? But it does look like it is unplugged and the connector is turned sideways.
By the way, did you say what the year and model of vehicle this is? Did you and I missed it?
The way the Signature description is, made me think it was a pickup with a shortbed. I took a chance and used a 2008 TB with a V8 and still could not cross the part number that I saw on the one you had circled, 52411434.
In the drawing above, none of the descriptions, in blue, match what the red arrow points at. If I was you, I would get to a dealer parts counter and give the number on your actuator to them and the application and have them pull up a pic and point to what you saw. I would bet that the part number crosses way back somewhere, in their system. Maybe even a NOS part on a shelf with 1" of dust on it.
If I had to guess, the one in the blue lettering is the Airflow Mode Actuator. The top description in the blue lettering.
Did you say....is it auto temp control or manual?
Does that question mean, do the controls let me set a specific temp vs just turn heat on or off?
If so, then it is auto - the first one - I set a temp for me and optionally a second temp for my passenger and the system does its thing.
Is there an "official" parts lookup website I can use to look up parts numbers, besides just winging it on sites like rockauto?
The manual control head will have the red and blue temp control lines in the center and the auto control head will have the red and blue lines in a circle around the knobs.
When looking up HVAC components, it is sometimes important to know which control head you have.
As I said, you don't have to "wing it". Take the pic and the number you found and go to the parts counter at the dealer and narrow the search down.
Looking at your pic, if the orientation is correct where you're looking up, the one that's circled is the mode door actuator. It has a white gear lever attached to it. The other one just in front is the defrost actuator without a gear lever.
Both of those are basically the same. The only difference is that the door actuator, which is the one you are saying is clicking, doesn't have the gear. The gear is removable.
Looking at parts listings on RA for the GM original parts, There is no difference between the manual and auto HVAC systems. These are listed for a 2008 TB.
In your case, yours is the one with the lever but if you want to save yourself a few bucks, get the one for defrost and transfer the gear from your old actuator to the new one.
Thank you for digging deeper than I could.
Guys I'm dying out here, any tips on how I can do this?
I got the new actuator. I'm in my driveway now, I just removed the old actuator. But I did it entirely by touch, no way to get my head far enough under the dash to actually SEE the actuator. And without being able to see it, I can't line up the new one and I especially can't line up the screw holes of the new one. Theres massive bundles of wires in the way, the duct work is moved partially out of the way as far as I can move it but its still in th eway, and the lower trim plastic is also in the way. This is probably worse than doing spark plugs by touch. Ugh I need to get a 4runner and be done with this crap for a while.
  • Wow
At 6'4" tall and 290 lbs., I have trouble under dashes. I soon learned that I had to bite the bullet and remove seats for better access. I have 2" thick kneel down pads and I put those between the tracks, after removal and then lay multiple fender covers over it all and then I am able to lay completely down and look straight up and do what I gotta do.
I am able to get my head into the footwell, so I don't think removing the seats would really help me. The problem is theres just too much shit in the way that I can't remove without breaking, everything has a million wires connected to it and the bunches of wires are massive and just physically hide the actuator.
ALL that said, i MAY have managed to position it in the right spot. HOWEVER, of course, one of the screws fell when I was trying to thread it in upside down, backwards, and with my wrist curled back around to reach the whole.
It looked like it fell right on the rug, but like magic, it dissapeared. I peeled back every piece of rug and plastic I could find and I've been waving a powerful rare earth magnet around under there but the screw literally just disappeared. Luckily they are super oddball, custom 5.5mm screws that will be basically impossible to find at the hardware store.
I also, when I get frustrated, will get a beer-when I used to drink and then take a break and look at the removed part to get a bearing on how the install will need to go. Picture lining it all up. I also would use small pieces of wood to wedge in places to hold trim out of the way, zip ties or bungy cords to hold harnesses out of the way. I hate having all that fall back in place while I am doing under dash work.
That screw is there someplace. As long as it did not fall in the void or in to a crevice. If so, you gotta go look, till you find it and get lots of light.
Bear in mind, that as you peel things back to look, the screw will give in to gravity and fall deeper down. When they fall, they can flip at odd angles and find the deepest hole to lay in.
I'm looking but i'm not finding anything. And its not easy to look when, i have to be laying on my back reaching up backwards over my head into tiny slots. But this is a powerful magnet, if its there it will catch it. I think it fell through a black hole. I think its gone. Like gone gone. Like in another galaxy gone.
BeezyBee
