Following the resolution of my front HVAC issues, the rear system decided to act up. I routinely use the rear system, with the 2nd row ceiling vents turned forward to provide quicker heat relief with less air noise so I can enjoy my music.
Was leaving the office one evening, and noticed the air blowing on my neck from the 2nd row vent was warm, and the rear system is never used for heating, so the temperature actuator must have failed. This morning, pulled the panel to get back there, and tried to remove it, but it wouldn't budge. After some pulling and prying, it eventually came loose, but snapped off part of the stud for the temperature door with it!
Replacement actuators seem cheap enough, but can't seem to find the door anywhere. Haven't been to any of the u-pull-it yards in quite a while, and this is NOT the time of year that I'd want to be rummaging for parts out in the open weather.
I may try to repair it with some JB weld or something, but I'm also debating just leaving it as is, since I was able to manually turn it to the cooling side, and that's all I ever use it for. Decisions, decisions...
