Catalytic Converter Compatibility
AeroBlazer
40
New York
I was curious if anyone could confirm if the GM 15808213 Converter Assembly,Converter Assembly, would fit on the SAAB 9-7X Aero as I had someone tell me it should but couldn't confirm and mentioned the positions for the converter in later years changed on the trailblazer
  • Wow
Reactions: movietvet
I was curious if anyone could confirm if the GM 12709243 Converter Assembly, would fit on the SAAB 9-7X Aero as I had someone tell me it should but couldn't confirm and mentioned the positions for the converter in later years changed on the trailblazer ss
Sure would help to have vehicle information. C'mon man!
Converter according to the website is for the 2005-2006 5.3l trailblazer/ envoy
My SAAB 9-7X Aero's converter is starting to go and my state does that stupid CARB bs but OEM doesn't have to be carb compliant and my cheapest option at this point
This "parts desk" seems to imply a same fitment across platforms...
ADDED: of course the part listed is not available but the information would appear to apply IF it is accurate.
Yes they looks like it should fit but would like to be sure before buying the part
I am going by the engines listed inside the listing which shows both "models" of vehicles, non-saab and saab. As with most "parts desks", their data is provided by others even places like rockauto don't really confirm fitment at 100% but back up "errors" with return policies... which might not be a good outcome if things are too far gone in terms of install / shipping / removal effort. Maybe you could email the linked site to see if they have any more incite.
ADDED: I see now what you are saying about the part that you quoted. AI says your part is from a 1.3l 3 cylinder engine.... what! where did you get that number from? So then, I guess you are asking more of "modify" question using two of those for your v8?
:smile:
ADDED: maybe the part number is 15892954.
I was able to find this and apparently I put the wrong model number in the first post, my apologies
ah... now your post makes more sense as you are wondering about the years "differences"... which you kind of implied later... but I couldn't make out how that correlated with the original number posted.
The number that I posted was for the 2008 chev trailblazer which has been replaced by the original link that I posted. I guess the question is why are you trying to use the earlier model year system?\
ADDED: I see it is something that you can get.... but based on the search, it appears that the earlier model is not "transposible" to the later models ... specifically the earlier model appears to be for only 5.3l while that later version is across all v8 engines which were redesigned in some form.
Can't find an OEM one for newer years and OEM doesn't have to be CARB compliant making it my cheapest option
They are legit, customer service/communication is on the meh side to be honest. I've had better service using GM Parts Direct. Why not just go with a universal CAT from Walker or Magnaflow and just have shop cutout the old one, and weld the replacement in?
The passenger side on my Envoy went bad back in 2019, and I ordered a Magnaflow one and it costed me about $250 for a shop to swap them out.
Gm parts giant was the only one in stock and thank you for verifying
Was the only legal way to not have to use a CARB compliant one
sneakypete
