Amazon Product Best Price EVER on a Hantek CC-65 Low Amp Current Clamp!
If you have entered the realm of using the Low Priced Oscilloscopes for your Automotive Diagnostics ...including whenever Diagnosing PARASITIC DRAW-DRAIN events, Amazon has SERIOUSLY Dropped the Price on the Hantek Model #CC-65 Low Amp Current Clamp at around $67.00.
THIS is MUST HAVE GEAR for the Up and Coming Diagnostic Technician as a Great Video of HOW this tool can be employed for Battery Drain and Relative Compression Tests, etc., comes from Eric "O" of SMA (South Main Auto) is LINKED below and I mention that for that application as a Passive Current Clamp used around the Negative Battery Cable must be done with its Big Brother Model #CC-650 Current Clamp is the better way to go!
Note that the Snap-On Low Amp Clamp and the similar AES-Wave Low Amp Clamp being used by Eric "O" in the Video Tips the Wallet Scale at around $300.00...
while the Hantek CC-65 wil do the same Job for a Whole Lot LESS Moolah!
61EQzeYi3+L._SL1500_.jpg71er5pg4POL._SL1500_.jpg71danU-L5QL._SL1500_.jpg613mbQp6vkL._SL1500_.jpg61LlV5vNpPL._SL1500_.jpg6124zmaIw3L._SL1500_.jpg71hbkX2svlL._SL1500_.jpg71vLWmEjJsL._SL1500_.jpg
PS... For those with 4mm Banana Jacks on their Common DMM interface, THIS BNC-to-4mm F Adapter will be required:
cobalt60
