When you blow the fuse, does it kill the high stop light too or just the lower side lights? There are 3 fuses for it, one under the hood and 2 under the rear seat, under your rear seat you will find #16 is for your high stop light mounted above the window, and then #34 which is for your left and right stop lamps that are on each side of the truck at the back. Maybe what you can do is ride around the block real quick with one of those fuses disconnected and see if it blows #12 under the hood. If it doesn't then that tells you which one is part of the issue. I doubt that will change anything in all honesty. I would check for any broken or frayed wires where the stop switch is located on the brake pedal. It isn't a high possibility but still some chance that it is rubbing and shorting out on the frame that supports your dash. I had blew my fuse for the veh stop under the rear seat when I put in non CK style LED bulbs and it did not pop the one under the hood. Since you are blowing the one under the hood and not under the rear seat, it makes me believe your issue is under the dash with either the wiring or the brake switch which ive been told is a pain in the ass to get off our truck.
