CD player won't eject or load a CD...
db131994
21
I have to use tweezers to push the CD all the way in, or grab the CD to remove it... Anyone have a fix for that? I figure I probably need to replace the whole radio. From what I have read, it looks like I would need to have the Stealer reprogram the new radio / CD player for it to work. Anyone know what they charge for that??? Plus, any how to on removing the radio?
Thanks!
Go aftermarket and avoid the stealership all together. You'll have a better unit, better sounds.
There is a TSB for 05-07 radios failing to play and/or eject CDs. (TSB 07-08-44-017)
The procedure is to remove and replace the radio fuse to reset the radio in an attempt to eject the CDs and then, unfortunately, to reprogram the radio with a new operating system.
So you can:
1) See a dealer in hopes that reprogramming fixes it.
2) Replace with an OEM radio (new or used) then see a dealer to program your VIN.
3) Go aftermarket.
Have you tried pulling the fuse? If resetting the radio doesn't let you eject the CDs then it's not just a software issue and option 1 is out.
Hollywood1929
