At 99,000 miles, recently I started doing more frequent towing, including some extremely hot days >100 degrees here in Minnesota. Trailer weights under 3,000 lbs, but in some hilly areas. My check engine light has been coming on intermittently for several thousand miles complaining about a P0480 fan-clutch circuit, but local GM dealer hasn't been able to find the problem and says the fan-clutch is operating normally, so I can ignore that.
Anyway, after towing a couple of hours on that VERY hot day, the cruise control stopped working. I thought it might have been one of the three fuses in the CC circuit or the brake light switch, so I checked all that out. No trouble found...so I was stumped.
Then I read on another forum someone's suspicion that certain >>combinations<< of P-codes might cause the ECU to disable Cruise Control, though this is not found in the GM Factory Service Manuals, nor on AllDataDIY in any service bulletins. Sounded like an Urban Legend to me.
Anyway, after following all the troubleshooting steps documented in the manual, I plugged in my Tech2...and along with the P0480 I found the following NEW codes: p1133, p0136, p0016, p0014. I hate clearing codes before fixing the underlying problem(s), but in this case clearing the codes brought the Cruise Control back to life!
About a week later it happened again (again, while towing), and once again clearing the codes got the Cruise Control working again.
Just thought I'd pass this along, as I can now confirm it's a real phenomenon. I am curious though as to what the engineers thought they were accomplishing by turning off Cruise Control in the presence of these codes...maybe as a Machiavellian trick to punish owners who ignore their check engine lights? >;-}
