Rizzoj2000 Member Joined May 13, 2014 Posts 28 Jun 12, 2014 #1 Is there a place to take a fuel pressure reading in the engine compartment?
Sparky Member Joined Dec 4, 2011 Posts 12,927 Jun 12, 2014 #2 Yup, look on the driver side of the engine and follow the fuel lines. There should be a green cap you can loosen to then put a gauge on the valve.
B BRomanJr Member Joined Dec 9, 2011 Posts 371 Jun 12, 2014 #3 Sparky said: Yup, look on the driver side of the engine and follow the fuel lines. There should be a green cap you can loosen to then put a gauge on the valve. Click to expand... Green caps signify the Evap System test port, 02-04 had the fuel test port underneath by the filter, not sure where 05-up placed them.
Mounce Member Joined Mar 29, 2014 Posts 13,667 Location Tuscaloosa, AL Jun 12, 2014 #4 IIRC from one of MAY03LT's YouTube videos, it's on the fuel rail on 05+.
