02FailBlazer
I've decided that at some point in the future, I'm going to attempt the massive PIA job of dropping the oil pan to replace my oil pickup tube o-ring. Given that this requires taking apart the entire front differential/axle assembly, is there anything else I should do while I've got all that apart?
One thing I've determined is that my 4WD disconnect probably needs some TLC. I discovered there was a clear/pale grease flung all over the place on the passenger side when I was doing suspension work a few months ago and couldn't figure out where it came from until I read a few threads here and figured out it's probably coming from the disconnect. It doesn't look like CV axle grease and it's definitely too thick to be front diff fluid.
Any bearings, seals, etc. I should replace? Other parts?
