I changed spark plugs 3 weeks ago in my 06 TB, 91000 miles. Plugs looked good and I torqued the new plugs to spec. Last Monday it started to miss and run rough. After warm up the missing tended to go away, but the service engine light came on. I pulled plug #1 to start an inspection and found that #1 plug was wet and stark white on the porcelain, there was moisture in the spark plug well, and the top of the piston was wet. I figured it was a leaking head gasket. I pulled the oil stick and thankfully the oil looked normal; no milky color; bottom end bearings probably saved. I think I caught it early.
I took it to the Chevy dealer for his diagnosis. He said that #1 plug had over 4700 misses recorded and that other cylinders had random misfires. He drove it extensively and he cannot get it to miss or run rough. He said that the 4.2 in the 06 year had little track record of headgasket problems. He also said that there is no way that coolant can leak into cylinder #1 because of the water passage design. I am not so sure about that one. So he is tending to not think it has started to leak though he is not ruling it out. Yet, he knows something is wrong and he doesn't want to return it to me till he knows what the problem is.
Anyone familiar with the block and head design on this engine, or the same experience on this engine? If so, please comment.
