anthonyl79
So got a 2006 2wd Trailblazer that has the 4.2 i6, once again doing a v8 swap. What I am questioning now is the ECM. According to the gm part numbers the ECM's are the same. Ok no big deal right, NO. So I have build a gen iv 5.3 58 tooth reluctor wheel. So the 06 TB's 5.3 are a 24 tooth. So the question is when rewriting the software to the ECM with a tech 2, can I use the software from say a 06 truck that used a 58 tooth reluctor on that 24 tooth ECM but with 58 tooth software. No I'm not gonna change the reluctor wheel or the cam gear. Too much $$$ in the build to be swapping that stuff out.
Hope this makes since.
