No brake fluid at the Front Brakes
Doc3477
1
Sioux Falls, South Dakota
I'm not getting brake fluid at the front Calipers. Brakes were working prior to my R&R work. Installed new Rotors, Calipers and brake pads. At first, I had fluid at the driver's side caliper but nothing at the passenger side caliper. Decided to change the master cylinder after seeing how dirty (very) the fluid was in the original one. Disconnected the front brake lines and blew them out, from the calipers up and then from the connections at the master cylinder (removed) down. Air flowed freely both ways. Blead and installed the new master cylinder. Connected lines to the Master and removed the hose from the calipers. Now I don't have any fluid at either caliper.
Before I change out the hose lines, I wanted to see what other thoughts on this might be from the Forum.
Only other thing I can think of is the ABS valve is blocked or stuck. Have you tried or have the capability to do the ABS bleed procedure?
Ineverfollow
