the roadie said:We often go wheeling farther than that from home, to get to the good trails. Just sayin'.
1000+ mile roundtrips do happen.
Cable810 said:Ok then, why do you all prefer different shocks in the rear. Doesn't it ride odd with the different shocks?
Cable810 said:Dj I would love to go to the meets but I live at least 4-5 hrs from most of the MI members and where they are meeting.
walterc4553 said:At one time there was a list of all the makes and manu for shocks for our vehicle on the OS. It was listed by stiffness and response rateing. If I can find that I will add it here. Found it.
From the OS
markarock said:...it seems to shake out like this in terms of stiffness, from stiffest to softest:
- HD Bilstein aftermarkets for the Avalanche
- OEM Avalanche shocks mounted on a Trailvoy
- HD Bilsteins for the Trailvoy
- TBSS shocks
- OEM shocks for the Trailvoy
- bungy cords
- rubber bands
- "Marshmellow Fluff® in a calking gun"
- Blistein OEM shocks for the Trailvoy (with >100k miles)
Now this is only accounts for one characteristic for shocks. There are more like travel, length, rate of return.
If your parents are really making you stay with all one Brand they maybe consider the Bilstein HD for the Avalanche. It is longer so would not over extend when you do the lift.
After re-reading your post #17, I have to offer my condolences. If you're lifting the rear, your grandfather must have passed.Cable810 said:I'm going to be getting the BDS 2" Lift
If you want the PROPER and OPTIMUM setup, just get the BDS shocks. They are meant to go with the kit, and will come with all mounting hardware for no issues on installation.with No rear Shocks.
The BDS shocks that are listed to go with their lift kit. Asking the same thing over and over again is getting annoying. After 87 posts in this thread, you've been given MORE than adequate advice.What travel length is recommended in the Rear?
As you were advised multiple times.For the front I'm gunna do Bilsteins HD OEM Replacements.
You do not want Avalanche shocks in the back, by Bilstein or anyone. Just get the Trailblazer Bilsteins if you don't need additional articulation, or BDS if you do want articulation. As a first time offroader, I predict you do not need articulation. If you come back and ask "what is articulation" that will pretty much prove you have no Google-fu.What Bilsteins OEM Replacment Avalanche shocks do I have to get?
Not if you buy the Trailblazer Bilsteins or the ones offered with the BDS lift kit.Will there be any modifications to the shocks/vehicle to get them to fit?
As we are also. As we are......My mom is a bit concernd with me lifiting it,
And the little issue of your grandfather......just do to it making it a bit more top heavy.
Cable810 said:My mom is a bit concernd with me lifiting it, just do to it making it a bit more top heavy.
Cable810 said:My grandfather has yet to pass. All I'm wanting to do is see how much I'm gunna be spending. I guess I'm making this a bit more complicated than what it is.... I'm paying for everything gas, insurance, etc... Seeing that I'm still living with my parents I have to respect what there say is. The only reason why I don't want to get bigger tires is, I don't want that decrease in MPG and the Big Tire Noise. My Uncle had suggested that I do the bigger tires in stead of the lift. Cause what he said is that a lift only lifts the body, and the Bigger tires are where your gunna get ground clearance.
I have been reading other Build threads, here are some Builds I like. JamesDowning, HardTrailz,Fishsticks,Gordinho80
I feel that a 2" lift is gunna have very little Top Heveay increase.
djthumper said:It has been said again again in this thread, "Define your mission". This will define how your build will go.
the roadie said:I keep pushing on you to define your mission. I see I should have been pushing on you see if you were even going to be allowed to start the project.
Therefore ConradM's builds Is what I want to do to my TB. Now I have changed my mind about wheel spacers. I'm leaning on either 255/65/17 or 265/65/17. I kinda want to get bigger tires but I do not want to trim my wheel wells and lose mpg. I can deal with a 1-3 MPG loss but anything over 4..... So what is the biggest I can go with out having to trim and a without a 4+ mpg loss?Cable810 said:I'm looking at makeing it more off road capable. The kinda off roading I'll be doing is mostly 2 tracking. Seeing that I'm not seriously offroading. Now this is going to be a daily driver as well so I really don't want to sacrifice a whole lot just to offroad.
