My 05 Trailblazer (4WD, non EXT, 6 syl) runs fine. However yesterday, the check engine light came on for about 2 hours, then went off on its own. Today t came on once again. I took it to the local parts store, and the hooked up the code reader. They came up with two codes. The first was B0055 Vehicle Speed Sensor Curcuit, which shows as a history code. The second is P0014 Exhaust (B) Camshaft Position Timing - Over Advanced (Bank 1).
What do you guys suggest I do now. I've looked in search function and have seen things that look similar but there seems to be different terminology used in some cases. Is the P0014 code repaired by replacing the sensor behind the power steering pump that I have read about? If so where can I find a detailed (hopefully with pictures) how to on how to do it? If this sensor was bad wouldn't the car run poorly? Other than it's usual horrendous gas mileage, it's running fine.
As to the B0055 code, any information I find on that is very confusing. Any straightforward advice on wither of these would be greatly appreciated.
Thanks!
Thanks!
