P0135
JayArr
Mission BC Canada
Hi All
On vacation with the Envoy pulling our trailer up north to Yellowknife. The transmission I rebuilt is working like a champ but I'm getting random P0135 and P0053 codes. I changed the oxygen sensor in the exhaust manifold but they keep coming so I think I have a broken wire somewhere in the engine loom between the sensor and the PCM.
I don't have the time or patience to tear into the wiring looking for a bad connection out here in the field so my idea is to buy a spool of wire and cut a few inches back from the O2 connector and run brand new wires over to the PCM, cut the four over there and atttach. This should bypass the wire break, wherever it is, and let me finish my holiday without codes.
I do carry a portable butane soldering iron with me in the trailer so I can get good splices. Can anyone help me with a link or a .pdf of the wiring? (I don't carry my paper manuals with me on holiday) I need to know where the four wires connect to the PCM.
2005 Envoy XL.
Took a bit to find this for the 4.2L PCM. These are in two different blocks on the PCM (and it's from the 2004 schematic, fig 24 - 4.2L VIN S, Engine Performance Circuit 2 of 5)
See if it matches to what you've got...
30 pin connector
18 - Tan/White H02S Lo Sig B1 S2
23 - Purp / Wht - H02S Hi Sig B1 S1
(reference: 24 is unused, 25 is Lt Grn)
26 - Purp / Wht - H02 Hi Sig B1 S2
35 pin connector (30-65; 30-32 are the first three on the block, LH side)
30 - Black / Wht - H02S Htr Lo B1 S2
31 - Dk Grn - H02S Htr Lo B1 S1
32 - Tan - H02S Lo Sig B1 S1
(reference: 33 is unused, 34 is Lt Blu / Wht)
Pink wires on both sensors are FUSED
One more thing: When I was towing last month, my B1S2 (rear) sensor threw a code after a few hours when the engine was under load. Went away next morning after cooldown. Came back after loading the engine again. If your rear sensor is what's giving you the code, you may have a similar issue. (e.g.; I *don't* think you'd have a break in the wiring)
To Safely, Properly Test and Verify the O2 Sensor Heater (Current) and the Circuitry::
And just because it's new, doesn't mean it's good. If you had the exact same codes prior, yes, I would suspect the wiring, however, would suspect the new sensor.
A code P0135 may mean that one or more of the following has happened: O2 Heater element resistance is high Internal short or open in the heater element O2 heater circuit wiring high resistance open or short to ground in the wiring harness
Potential causes of a P0053 trouble code may include: A faulty O2 sensor Burnt, broken, or disconnected wiring and/or connectors Blown fuse or burnt fusible link Defective engine control relay
What brand sensor did you use? I wouldn't bother with trying to fix it in the field since it's just for the heater, which doesn't come into play once it's hot from the exhaust.
I used a BDW sensor and got the exact same codes immediately after.
When I put up the O2 sensor on the torque pro and watched it I could see it cutting in and out. Sometimes it would cyscle properly, sometimes it would get stuck at zero. If I'm sitting idling and it gets stuck on zero I can rev the engine and it will start working again. I'm pretty sure it's a broken wire inside the insulation that is intermittantly connecting and disconnecting.
Once I'm out on the highway it runs great.
I'm in a campsite on Lessor Slave Lake so it's a make it work sort of scenario. I grabbed three 25 foot rolls of wire and some heat shrink from Napa in Edmonton before we left. I'll let you know how this works out.
JayArr
Makes sense that at idle, it relies on the heater to make it work at the required 600f. At higher speed, it would reach that with the exhaust heat.
Did you check at the connector if the PCM is sending 12v to the two wires for the heater? How about the resistance of the heater on the sensor? I'd hate for you to muck around the wiring and it's another bad sensor.
This video shows some tests you can do:
Reactions: budwich
Well, I ran four parallel wires from the plug where the O2 sensor connects. Three of them went to the pcm and the fourth went to the O2 fuse..
No change!
So that disproves my theory that it was a broken wire in the harness.
No harm done the vehicle still runs as before.
I was curious to know if the code was because the current was below 0.25A or above 3.15A but I couldn't find a way to monitor O2 current using Torque Pro so I pulled out the Tech II. It shows the individual currents of the two sensors in one of the data menus. Sure enough there was no current on the forward sensor heater. The rear heater was alternating on/off and drawing about 0.65A.
I double checked that there was 12V reaching the sensor and there was. I checked the resistance of the sensor and it is 16 ohms. I even pulled the O2 fuse and the pcm connector and measured the same resistance between the power source point and where the other side of the heater connects to the pcm.
I am running out of tests and I am starting to think there is a problem in the pcm.
Any thoughts or suggestions welcome.
Jayarr
Maybe the sensor quits only at higher temps while driving? I dunno. Seems like a weird one but can't see the PCM as being at fault but have been proven wrong before on that. These are getting old. If you have a spare PCM or can get one cheap at a pick-n-pull yard, sure.
I do have a spare pcm but it's at home. I have had thoughts before that I should program it to match the one in the car and carry it as a spare but I never got around to it.
When I get a chance I'll pull the fuse and pcm connector and apply 12v to the pink wire and I'll ground the green wire and measure the current. if it's within spec I'll wait until I get home and swap PCMs.
These O2 sensors are powered all the time by connection to 12VDC switched on with IGN. They are what I call "switched to ground" in that they are turned on by having the other end connected to ground to complete the path. This is done in the PCM by what is commonly referred to as an "open collector" driver.
Since the current is also monitored the circuit probably also contains a very low value shunt resistor that the current must pass through on it's way to ground and the PCM can determine the current by measuring the voltage accross the shunt. This is a pretty common electronic circuit configuration in instrumentation.
It's possible that either the "open collctor" driver or the shunt resistor are damaged or that some solder connection along the way has cracked and opened.
It's aslo possible that I'm way off base and it's something else entirely.
It's sure fun trying to figure it out!
More to come.
JayArr
This may not be worth much but in my benchtop PCM resistance tests the C2/31 terminal (B1,S1 lo) reads from 850k to 870k to ground. Tested on 3 different P10 PCMs.
That's worth a lot, I'll test that.
Out of curiosity, do you get the same resistance if you reverse the red and black leads? That will indicate wheter the path to ground goes through a forward biased silicon junction (a diode or a transistor).
Also: Does the B1S2 low pin on the pcm measure the same to ground? (I would expect them to be similar)
For the reverse direction I will check this when I return to the house this evening. I remember checking some pins in the reverse direction but I didn't record the results.
Yes, the B1S2 l9 measures the same as B1S1 lo.
@JayArr
So if I use the same multimeter, an old craftsman with a max selection of 2000k, NOT an autoranging model and read reverse it starts at about 388k and slowly drops. After about 30 to 45 seconds it gets to say 380k. I haven't waited any longer to see how low it would go.
Both sensor lo pins behave the same.
Added note in edit: readings were done with ALL power removed from the PCM, even the always hot supply.
Here's the 'thing' that has always puzzled me about reading resistance in situ of a circuit. I have two autoranging multimeters and an older Craftman manual selection model. I can get no agreement on those two autoranging models. In the reverse direction one read about 15 megohms and the other about 8 megohms. In the forward direction one reads 28 megohms and the other reads open circuit (maybe beyond its range?).
All meters read a 1 megohm resistor just fine.
I don't like autoranging multimeters and avoid them when possible. They are more like toys and appeal to guys that don't have a lot of experience and hope the meter will do all the work. They always seem flakey to me, taking a long time to decide what range they should be on. The delay can even be dangerous in a testing environment, I watched one tech smoke an inverter waiting for the meter to tell him he was overcurrent. A regular needle meter tells you that immediately and you power down LOL. TBH I don't even like digital meters much and my daily meter is an old Simpson 260 (with a needle).
(if you put a $10 analog/needle meter and a $500 autoranging Fluke on the table I'd take the analog)
Resistance is measured by sending a current through the circuit, that's what the battery in the meter is for. As the battery ages the resistance can vary slightly but not much.
What can change from meter to meter and even from one resistance range to the next is the voltage applied by the meter to the circuit. If the voltage applied is above 0.6 or 0.7VDC it'spossible for a meter to forward bias a semiconductor junction and turn it 'on'. This is easy to see by taking a common diode and measuring it. On my meter I get a reading of about 15 ohms 'forward biased' and infinite ohms 'reverse biased'
Here's how this becomes useful. If you measure a resistance in circuit or 'in situ' as you described and if you then reverse your leads and get the same reading then you are probably reading a purely resistive component.
If the reading changes when you reverse the leads then the lower reading might be through a semiconductor junction.
Example: Take a 1kohm resistor and a general purpose diode and twist them together in paralell. Now when you read them forward biased you may get a reading around 15 ohms because most of the current the meter sends out is going through the diode. Reverse the leads and you will read 1kohm because the diode is reverse biased and 'off' or non conducting so the meter current must all flow through the resistor.
I don't know what to make of the 380k versus 850k but it's good to know both numbers when comparing.
JayArr
Reactions: azswiss
Back to this problem today. I'm still getting the codes and the heater in the forward O2 sensor is not coming on despite it and the wiring being OK.
My conclusion is that it's a PCM fault. I have a spare PCM that came with the engine I bought so I opened it up this morning to see what I can see. It's a multi layered unit with the inputs connected to a circuit board that has no active components, just the connections to the physical world.
There is a mylar/foil ribbon cable that connects the input circuit board to the active circuit board where all the action happens. The connections are all just pressure contact when the case is bolted together so everything comes out nice and easy.
I followed C2 pins 30 and 31 (O2 heater circuits) into the PCM and through the ribbon connector and all the way down to the lower left of the circuit board where they attach to two Field Effect Transistos (FETs). the output of the FETs go through 0.1 ohm reistors to ground.
The FETs are the lower two in the bottom left corner and the resistors are the grey rectangular components that say "DALE R1"
Here's how the circuit works:
Power is applied to both heaters from O2 fuse 29, these are the pink wires. They provide 12VDC to the heaters in run or start. This power is not controlled or turned on/off by the PCM, it's just there.
To turn the heater on the PCM applies a signal to the gate (G) of the FET that is connected to the appropriate sensor. This turns on the FET and it acts like a switch completing the circuit to ground and allowing current to flow from the fuse, through the heater, through the FET and finally through the resistor to ground. At this point the heater will be 'on'.
The DALE R1 resistors are there for one specific reason, so the PCM can measure how much current is going through the heater. They are a very small value - 0.1ohm - so they don't materially affect the circuit or the heater but by knowing the resistance and measuring the voltage across it the PCM and calculate the heater current.
Typical heater current is 0.65Amps and at this current draw the voltage measured across the resistor would be 65 mV. Quite easy for a microprocessor to measure.
In my PCM the forward heater does not turn on so one (or mor) of three problems can exist.
1) the signal to the gate of the FET is not being supplied
2) the FET has stopped working
3) the resistor is burned out or the solder connection has opened.
My guess is 3)
So this has all been fun but I'm hesitant to just pull the PCM off my running daily driver and open it up. If something went wrong I would be out of cars right now.
Is there a way to copy the PCM that's in the car to the spare I have (settings, VIN, Odometer and all) so that if I can't fix the one in the car the spare will run the car?
I have a Tech 2 clone.
If I can get the PCM 'backed up' I'll pull the PCM from the car and see if I can repair the FET circuit for O2 sensor #1 so the heater starts working again.
These PCMs have been pretty bulletproof so far but as this platform ages they may start to show more and more faults and knowing how to repair them would be handy.
Reactions: TJBaker57
I don't think you can "backup" the PCM. All you can do is program the other PCM with your VIN using Tis2000. You will still need to do the 30 minute security relearn.
Shall I guess you used the Tech 2 to turn on the forward heater and saw no appropriate amperage reading?
And verified power at PCM connector 2, pin 30 feeding through the heater circuit from the fuse?
My diagrams show this power hot at all times. Have not verified this in a vehicle.
Adding a quick edit to say the odometer is maintained in the Cluster so this is not an issue with changing a PCM.
Yes and yes.
Also, if I use an extra wire from pin 30 to ground the heater turns on and I can measure that there is current flow - indicating that the heater is OK.
Look at the diagram you posted in post#4 of this thread. "hot in run and start"
Can I program a 2003 PCM to be a 2005 PCM with a new VIN?
Ah, I looked at a 2002 wiring diagram yesterday and that 2002 diagram has an error. It shows "Hot at all times" on the engine wiring page but the power distribution diagram shows it going through the ignition switch terminals B and C which are hot in Run and Start. This is not the first of such errors I have stumbled across.
This I don't know for certain. A number of suppliers listings suggest it can work but then some suppliers list PCMs that fit from 2002 to 2007 which cannot be right since they used 2 different PCMs in that time span.
From what my research shows, 03-05 use the same PCM. Just need to load it with the 2005 VIN calibrations.
Hi All
I'm back to this problem (I've been driving around for 18 months ignoring the CEL)
I pulled the ECM and dismantled it and found nothing obviously wrong. The resistors are OK and the FETs do not look burned or damaged. I put it all back together but still do not get current flow through the front O sensor heater.
I have a spare ECM that came with this engine. I'm thinking of swapping it in to see if it solves the problem before I go to the trouble of replacing surface mount transistors.
Question:
If I swap this ECM into the car and do the 30 minute security relearn does that write the key IDs to the ECM or does it write the VIN# to the security module?
If I subsequently swap the ECM back will I have to do the relearn again or will I end up with two ECMs that both match a single key?
Thanks MRRSM, I'm sure that you meant well but that's 7 minutes of my life I'm not going to get back and the video did NOT answer my question.
My question wasn't how to do the relearn procedure, I have that information. I was asking a more specific question.
Question:
The ECM learns a new handshake code with the BCM for the "go ahead start" signal. The VIN will be mismatched to the BCM but will still work. Only thing you'll need is a CASE relearn.
Both ECM will have learned the same handshake signal and can you swap them at will.
forget my post as I see further back that you have the impedance test info already.
having said that... did you ever follow thru on post 15?
That's fantastic. It allows the spare ECM to be carried on vacations and road trips and to be used for diagnostics.
Budwich - sort of but not really, once I determined that everything outside of the ECM was OK I started focusing inside and rather than chase resistances I just pulled it apart. It looks good inside the ECM but that doesn't mean the transistor is good. I'll try swapping ECMs and if the problem persists I'll have to figure out why but I suspect swapping ECMs will eliminate the problem.
So today I swapped the PCM, installing the 2003 that came with the engine when I bought it from the wrecker. It's been running on the 2005 PCM for years without trouble. I did the 30 minute relearn and then the crank shaft variance relearn. All is well.
So my O2 sensor problem seems to be fixed. When I look at the two sensors with my Tech2 they both seem to be pulling a little over an amp through the heater circuits and that's what I wanted to see. I'll drive for a week to make sure but it seems that my P0135 codes were caused by a bad circuit inside the other PCM.
Now the bad news...
My gas gauge no longer works. It shows empty and the light is on. I filled the tank a few hours ago and it was reading full before the PCM swap.
When I look at Rock Auto I see different part numbers for the 2003 and 2005 fuel sending units. Does anyone have the specs on resistance for the two? I'm wondering if I can add an external resistor to make this work or if I have to drop the tank and replace the sensor.
I'm going to assume the wiring harness is the same and the PCM pin locations for the sender did not change since the computer model is the same.
Any help appreciated. @TJBaker57 ?
A little googling and it would appear that the PCM connections are the same for a 2003 and a 2005. The power comes from C1-22 to the sending resistor and then back to the PCM at pin Cq-8 which is a low reference (gnd).
I've also seen a diagram that says the 2003 has a 40 ohm sensor but I haven't found the resistance for a 2005 sensor.
EDIT: Just found a site that says they are both the same resistance 40 ohms empty and 250 ohms full.
I guess I'll go out tomorrow and see if I've got a bent pin or something.
I cannot find documentation right away.... But in the back of my mind I have this memory that there was a change in the way the fuel level sensor sytem works.
I think in some years fuel level increases with increasing resistance from the sensor while in other years the fuel level decreased with increasing resistance.
I will see what I can determine with may assortment of PCMs.
I did another test this morning.
I pulled C1 (Blue) and measured between pin 8 (Low Reference) and Pin 22 (Fuel Level Sensor Signal - Primary)
I measure 40 ohms. Since this is not zero or infinite I can rule out a short or open in the wiring harness no? So let's say it's correct.
I swapped the PCMs back so the 2005 PCM was installed. Turn the key and the fuel gauge says full and no light.
Swap the PCMs so the 2003 is installed and the fuel gauge says empty and the light is on.
Despite what I've read on some web pages it appears that the fuel sending units changed between 2003 and 2005.
I just confirmed my memory here as well.
On a 2005 PCM here a shorted sensor circuit is an FULL fuel tank.
On a 2003 PCM here a shorted fuel sensor circuit is a EMPTY fuel tank.
Edit: I might have posted this back wards, checking now
2nd edit: yes I had it backwards. If I had the ability I would strikethrough my previous errors but evidently strikethrough text is not available at least on a phone interface here. So all I can do is edit to show the correct wording.
So both are 40 to 250 ohms but one is reversed to the other?
Technically, that's easy for the engineers in Detroit, they just re-write a few lines of code.
If that's the case then my fuel gauge should just run backwards. I think I'll drive it for a week and see if it comes off empty and rises up to full as the tank gets lower.
I've also set my trip meter so I don't forget and run out of gas.
Thanks TJ!
briancayko
