Uncleenvoy
Yeah, zip tie makes them stop coming apart when you're trying to get them into the rack. Using a fully threaded bolt instead of the stock one also make the job a lot easier. With the thread started you can use a long thin screw driver to rotate the lines into position, you can probably have a third person do this from the top as you watch and run down the bolt.Easier said than done..cant get the hoses line up to go in the rack..gonna zip tie them together at that bracket where it goes in the rack and see if that helps stop the one from slipping out of the bracket.also found plenty of access when approached from under car going at it from left of the front driveshaft..i can probably get the seals out now..try again first light tmrw
Going by the look of the old seals I'd have to say that either the rack &pinion was replaced at some point our there was a leak and the seals got swapped out. My Envoy and the trailblazer SS seals didn't look anything like that on the way out they fell apart on the way out and some pieces stood inside the rack. I had to dig it out with pick tools and a turkey baster to suck the small pieces out.Got the old ones out no prob..used 10mm wrench from under the truck next to driveshaft
Ford at least required ATF as a PS fluid starting in like the late 80's IIRC, and if you tried to use PS fluid it would destroy the PS pump seals and make it really noisy and weak. A lot of other OEM's switched to it as well, it was one less separate fluid they needed to stock on the line. Of course, these days most cars and trucks shy of 3/4 ton use Electric Power Steering, which obviously can't leak. Of course, if a rodent gets into the harness it can mess it up. Worst of the worst though are Electro-Hydraulic PS systems, which use an electric motor to drive a hydraulic pump, creating even more failure points while keeping the old ones.You can use trans fluid as power steering fluid?
