Rear HVAC Actuator
2006 EXT LT 4.2
I'm currently struggling with the problem of rear HVAC.
This is a matter of popularity. There are many threads.
I read about not only the HVAC issues but also about calibration after replacing the alternator.
Something close to my problem was in the TRAILVOY thread, but it was unsolved.
A similar problem occurred in 2021, and I replaced two rear actuators. For several years, there were no issues.
I replaced the battery this time, but for more than a month, there have been no issues.
But recently there has been a problem.
After the engine starts, the rear blower does not move.
After a minute or a few minutes, you will hear a loud knocking sound from behind.
The knock continues for quite some time.
The rear blower then moves.
Calibration was also performed.
I removed the actuator and checked the inside, but there was no chipped gear.
I have a question: Does the fuse on the HVAC1 have something to do with the rear calibration?
I watched it on YouTube and he had reset the knocking sound of the rear actuator by removing the HVAC1(fuse39).
I have removed the HVAC2(fuse36) and performed the calibration, but will it be effective to remove the HVAC1?
I wish I could give it a try, but I'm hesitant considering the possibility that the front HVAC actuator might break.
If it has something to do with the rear, I'd like to test it out.
I also looked at the image to see the position of the front actuator gear.
Is there an image of the correct position of the gears somewhere on the rear actuator too?
There may be other things to fix.
1. Auxiliary Heater & Air Conditioner Control Assembly
2, MODULE, BLOWER MOTOR CONTROL (AUXILIARY HEATER)
3, or reset by GM dealer.
Thank you very much.
2006 EXT LT 4.2
