Replace rubber brake lines, yea or nay?
C0267 is pretty definitive if it's been diagnosed properly to rule out a wiring or power issue to the module. If the valve is stuck open, I could see that causing the issues.
Hmm. I'll take a close look at any connectors/wiring/grounds I can access before buying anything. Guess I'll pull and inspect the ABS fuse too.
Just seems weird that this pops up after changing some brake parts. Maybe the first fluid flush was enough to cause something already on the verge of failure to give up? Dunno.
Should also mention I've never gotten an ABS light.
Kdew02
