Spare tire hoist recommendations/reviews
Just found out from their newsletter, they now have spare tire hoists for our trucks. It supposedly has an anti corrosion coating but I wonder if they fixed the rust problems with the secondary lock? Maybe I'll email them to find out.
Dorman Products - 924-509
$77 at Rockauto. $100 on Ebay! :eek: :eek: :eek: :eek:
Correct me if I am wrong but is this not covered under warranty no matter how old the truck is as per DOT regulations. I believe it is so I Canada.
moose, if the pic is of the actual item, it doesn't look there is a secondary latch. It looks like just a spring to keep tension on it when you tighten the cable and bring the wheel up.
I like it. A no-nonsense (read: no bs) way to do it.
I'd be astonished if this was true. A quick Googling didn't show a reference. Can you look into it further?
Hey Roadie, just spoke with my contact at the GM dealership and he tells me it is policy to replace if it fails and customer complains. But if it fails due to no maintenance then the customer pays. No bulletins or recalls noted.
This is the response I got from Dorman:
Thanks for your inquiry. Sorry we do not produce any hoists or their parts.
-----Original Message-----
Sent: Monday, January 20, 2014 7:05 PM
To: Techline Marketing
Subject: Dorman 924-509 - Spare Tire Hoists
Good day,
Just saw that this is now available. The description mentions that it is coated to prevent corrosion. The main problem with the originals is the secondary latch failing to release due to corrosion. Has this been addressed with this hoist? The only way I can see that this can be prevented is by making the secondary latch out of stainless steel.
Thanks.
I did put THEIR part number in the subject line. :duh:
Good day,
Thanks.
Looks like their lawyers got to them first:lipsrsealed:
Why would Dorman post a page with a part number and a picture with applicable fitments? Could the person on the other end just be incompetent? I hope so otherwise Dorman loses a point in my book.
Answers!:mad:
Yeah, I replied with a link to their page about it. Should be interesting :cool:
in for results as ours has been removed since week 2 of ownership.:popcorn:
OK guys, just hang on a bit as I have just been contacted by someone from Dorman's new product development group via PM. So hopefully I can get some good info directly from the horse's mouth.
Alright, here's the 411 on this hoist. They have made improvements as follows:
1. Cable spool is packed with weather proof grease to resist corrosion.
2. The secondary latch has been eliminated to address jamming issue.
3. The cable end was switched to alloy instead of original steel to prevent spare tire loss due to rusted cable end.
Sounds like a solid part to me. On top of that, they are sending me a sample for me to provide feedback on. Now until things thaw a bit around here :redface:, I won't be able to install it but will provide feedback on the hoist itself.
Oh and I asked how he found this thread, his reply:
I regularly search vehicle forums I.E. Toyota Nation, GMT Nation, The Diesel Garage, Dodge Talk, etc. for product ideas and feedback.
Hmmm, no mention of TrailVoy :raspberry:
So we are being watched for ideas. :lightbulb:
Please keep us updated!
I think their product improvements are good enough that I might just refit this preemptively.
Well that's pretty awesome. Would have been nice if it was available when I replaced mine 3 years ago, but oh well! So far so good on my current one...
I haven't used mine ever so it's been 8 years. If this gets the thumbs up I'm buying this and also going to probably need to put a new tire on the spare wheel.
I would test yours out before you really need it. I made that mistake the first time I got a flat tire, at night. What a pain in the a$$.
I will be on board as well.
Oh no, from what I've read on here, I basically consider it to be dead weight, I'm basically driving around without a spare in my mind right now. Think I will do the dorman retrofit, get a new tire on there, and keep a bag of better tools in the back so I won't have to use the stock ones (jack, socket, wrench, gloves, flashlight/s).
Rouxzy said:
I purchased this a couple of weeks ago for my 9-7x. It is a good quality item.
How much did it run you. It does not list a price on the Dorman website.
Edit: found it on Advanced Auto's site for $158.99. Was it a pain in the a$$ to remove the old one and install new?
I had the truck on a lift....and was about 5 years ago now. But I remember it being two bolts, easy to access. Don't recall having to use any spray to loosen the threads, and the truck lived its whole life in rust country.
When I noticed mine had rusted out during a check, I put a floor jack up to hold the tire weight and had the assembly&tire down in a few minutes. Put the bolts back in to keep the threads good. Tire goes in the back when I drive too far.
The new one will go in just as quick I am sure. I just don't want it seizing up if I go too long without use.
The website posted in post #1 shows it only available for EXT models. I am assuming that this might be an oversight on their part and that this will also fit the shorter wheelbase models as well..??
Does anybody know how to get the spare tire off once the thing has gotten jammed. I went to check the air pressure of my spare and I could not for the life of me get the thing off. :confused:
I had to force mine to get it to drop enough to cut the cable. Held the spare up against the chassis, got the cable to stick thru far enough to get some cutters on it, and chopped it. Then dropped the spare, unbolted the busted hoist, and put on the new one.
I have received the sample hoist from Dorman but I have been so busy, I haven't even opened the box. I might do an unboxing video of it and post it.
:popcorn:
I hope it is all that. I'd put it on after work.
I kicked the living sh!t out of mine the time I took it off. It came down when I tried to lower it the second time, I however would recommend something a bit less brutal
Penetrating oil and time. If that doesn't do it, engage some power tools with extreme prejudice.
The first time I took it off I soaked it in PB blaster, it worked that time.
Interested to see the product.
I pulled my old one off to send it to you, it was a bit more jacked up removed than it appeared. Sorry for not messaging you back, I get side tracked so easily.
Blazin: I got your msg, just opted out of the oem design because it will seize again. No worries.
I put a jack under the spare and took the 3 (?) bolts off the assembly and dropped the whole thing. Snip the cable and trash the metal. Put the bolts back in the frame to preserve, just in case. Throw spare in back if you want.
Why leave it up if it has seized? Just cut it. How frustrated will you get if it is dark and it won't come down?
I still need to get a proper sized spare and figure out how and where to stash it...
No unboxing video but these pics will have to do as a review. So far, looks good. They did do away with the secondary latch that is so problematic on the OEM part. Only grease I saw was on the winch mechanism. I'm not sure what the cable is made of because it was painted. Not too sure what to make of that. If it was stainless, why would they paint it? It is magnetic but then not all stainless steel is non-magnetic.
I'll have to get in touch with my contact at Dorman to find out about the cable. This was a major safety issue when car makers started putting spares under cars and trucks and they were falling off when regular steel cables were rusting out, which is why they went to stainless steel and added these damned secondary latches.
Bad news. Here's the answer I got:
The cable is made of steel with a black corrosion resistant coating.
Looking at this coating closely, it looks like paint and peeling off. I had flecks of it on my hands. Given that there is no secondary latch and the cable is made of steel and will rust anywhere salt is used, I will not be installing it. I'll just keep my old one made with stainless steel cable and keep putting the spare upside down to prevent the secondary latch from jamming. I cannot, in good conscience, recommend this product :no:
I'd be sure to tell them that.
Yep. Sent him an email with a link to the post.
I purchased a tire hoist from Amazon, APDTY 035610 ($87.00), and installed it yesterday (5-27-21). Did a bit of research and there's several on the market ranging in price from around $40 to $210. Wanted a decent one, so stayed away from the lower priced ones and settled on this.
Looks like a decent part, had no trouble with the fitment. The cable is low quality stainless, and the end (at the tire) has a swaged (swedged?) fitting that goes through a pretty heavy spring. The spring sits on a boss on the fitting. It does not have the secondary lock like original GM.
When I got it on and raised the tire up I noticed the flat end of the spring wasn't sitting square on the boss, so lowering the tire a bit and finageling with a channel locks got it in place. The reason I did this was the spring is flat on the part that sits on the boss, and wider at the top (like a beehive valve spring). I was afraid if the spring wasn't sitting correctly the swaged piece might pull through and lose the tire.
There's a 10mm hex type fitting on the back that can be used to raise and lower. Did that a few times, worked fine.
I'll be checkin for rust and stuff evry time I do an oil change, and let everyone know how it pans out.
Owen.Naughton
