Starter Remote Device
alleycat3
27
Houston Texas t
I saw on u-tube where a mechanic was doing a compression test and had a starter relay connected to the fuse with a on and off switch , anybody know what it's called?
Yes... You had the nomenclature perfectly...It is called "A Remote, Push Button Starter Switch" and it is used to bypass the Ordinary "KEY-ON" Starter Solenoid Activation after being connected as per these images:
These are available on Amazon from various Auto Accessory Companies:
51sMAi7caZL._AC_SL1500_.jpg61cVI+HIY-L._AC_SL1500_.jpg71AvlQGePKL._AC_SL1500_.jpg71CcdvJlfEL._AC_SL1500_.jpg71HZtbZTbNL._AC_SL1500_.jpg81afswdd-FL._AC_SL1500_.jpg2011-02-18_012157_0.jpgIMG_1389.JPGsdr0059_solenoid_9573f19cb2e2fc1f13e6ffe259d983e7545e13bb.jpgStarter+and+remote+starter+switch1375300172.jpgVOLTAGEDROPTEST.jpg
Reactions: alleycat3
But instead of connecting it directly to the starter solenoid like in the pic above, you could pull the starter relay in the fuse box, use a couple of small spade connectors, put the connectors in the relay slots that correspond to + and the solenoid. Or just do what I do, use a jumper wire.
Reactions: alleycat3 and mrrsm
Not quite as convenient though when performing a Compression or a Cylinder Leak Down Test...
View attachment 113357View attachment 113358View attachment 113359View attachment 113360View attachment 113361View attachment 113362View attachment 113363View attachment 113364View attachment 113365View attachment 113366View attachment 113367
Thank you sir!
morezy
