Oxygen Sensors
Rizzoj2000
04 TB. Are both Oxygen sensors on this vehicle the same part number? should I stick with GM or are Bosch ok?
downstream you really don't need to change it unless you have a code or purchase a new CAT....
True, but if he's willing to just knock them both out since he's already down there it's feasible. The upstream is known to get "lazy" after a while, I would bet the downstream may also (though in a perfect scenario there should be no or very little fluctuation in voltage anyway) but of course it wouldn't affect fuel economy.
Check your 02 mine came with a Denso from factory.
IIRC, Denso makes/made the AC Delco O2 sensor. Bosch is the one our trucks have a problem with.
Reactions: KNBlazer
Yup, usually Bosch is a bad idea. That said I had a Bosch in mine for quite a while and never had an issue with it, but given the history I'd rather just use a known good sensor brand to start with and not risk it.
Besides, the Denso was cheaper than the Bosch anyway.
Denso is also cheaper than ACdelco. Make sure to use a copper anti-sieze or copper gasket on the threading.
The AC-Delcos I bought from Amazon - referenced in above post - already had the threads precoated with anti-sieze. I was very pleased with that.
I think I've read about members using NGK plugs, but I'm not recalling any discussion about NGK sensors. In the absence of data, go with what we know works.
spb_osu
