Rizzoj2000
- Joined
- May 13, 2014
- Posts
- 28
04 TB. Are both Oxygen sensors on this vehicle the same part number? should I stick with GM or are Bosch ok?
True, but if he's willing to just knock them both out since he's already down there it's feasible. The upstream is known to get "lazy" after a while, I would bet the downstream may also (though in a perfect scenario there should be no or very little fluctuation in voltage anyway) but of course it wouldn't affect fuel economy.KNBlazer said:downstream you really don't need to change it unless you have a code or purchase a new CAT....
The AC-Delcos I bought from Amazon - referenced in above post - already had the threads precoated with anti-sieze. I was very pleased with that.seanpooh said:. Make sure to use a copper anti-sieze or copper gasket on the threading.
