Are you able to pull the EBCM codes? This may point to an issue with the EBCM that may affect the PCM in some way. Maybe an electrical or ground issue or the Stabilitrak is erroneously kicking in and pulling the throttle on the PCM. However, this would not explain the P0011 unless an electrical issue is also causing it.
No, unfortunately not. I think I have to buy a more serious bidirectional scan tool for this matter,but I don't want to put to much money on that.
I only have Torque (paid version)
Anyone have a recommendation on that matter?, a Chinese Tech2 is to expensive for me unfortunately.
I have read that some have replaced the wireing harness for the cps and magnet, but I can't find one with 5 wires, Rockauto only have 3 wire harness Wich is kind of strange.
This is a very common problem with the 6.2l engine, there are posts all over the net about this. But never ever have I seen a " do this, this and that and it's fixed" solution. It seem like every poster just gives up. Except one guy on YouTube that have done in principle a full rebuild of the engine and thinks that it was when he put in new cambearings the problem got solved
. I hope that is not necessary.
It has in the past happens a few times that I whith the P0011 code pending and stabilitrak light on drove in to a roundabout , and the engine just died on me. And refuse to start again.
I have then learned how to get it started without letting it get cold first.
Gas pedal to the floor and 3 to 5 start attempts and then it starts again. Sometimes it knocks/dieseling when you revs it a couple of times but that goes away quickly. Just like the timing is really off.
One time when I was on cruise control at 70mph it started to really struggle up a very mild incline, I disconnected the CC and put my foot on the pedal and it was totally out of power. When I let go of the throttle it just died.
Rolled to the side of the road and, no start. After I did my starting trick it run just fine for the rest of the way. At just this incident I had No codes and no lights
Like I said, it drives me crazy
