Busy day after some night shifts. Had been soaking the rear hub on my quad in anticipation of hitting it with the puller. Ended up rotating heat, cooling spray and a ballpeen to get that hub removed. Took a bit as that bimetal corrosion and rust did a number. Then got the axle tube and then axle out.
The tube seal was MIA and the bearings were absolutely thrashed. I have to get a long set of snap ring pliers and then a long punch to knock the old and absolutely seized bearing races out.
Then make a comprehensive list of bearings, seals, brake parts and so on to rebuild the thing.
). The JB Weld held up nicely. I looked up the actual torque for that plug and it's just 11 ft-lbs. Also pulled the pickup tube and found some junk on the screen. Some brake cleaner and back in it went. Put the tank back, hook up all the hoses, fill it up with oil and let it sit.
Calcium deposits and buildup is a big nuisance, especially in the toilets above the water line. So far my best solution was to inflate a balloon in the bowl to be able to fill it with water and pour vinegar to let it soak and loosen things. Somewhat effective, but less than ideal.
Will grab the respirator next time, but this is definitely the way to go from now on.
