Boricua SS said:A lot of people just cut the radiator hose and add a t type adapter with a sending unit in it and then hook it up to a gauge...
Water Temperature Sender Attachments
Mooseman said:It wouldn't be that hard to drill and tap into the top water outlet for a sensor. I did it for my efan controller sensor. And yes, you would use the top hose as the water circulates out of the engine through the top hose to the radiator.
the roadie said:The temp gauge also lies, but it's a smaller lie than the oil pressure. The PCM filters and averages the "real" temp (that you can obtain with a scan tool) so the needle doesn't appear to move away from straight-up-12-o'clock under normal driving conditions, when the truth is that is varies from 190-220 or so.
meerschm said:View attachment 17100
I got this from tapping the data.
you do not need to insert another sensor to get the real data, just have to read from the computer via the OBD port.
next one is from my TDI, in centigrade,
in both cases, when you get close, the display on the dash remains steady.
you may want to check out these:
ScanGauge - Trip Computer + Digitial Gauges + ScanTools
what would you use for display after you insert additional sensors?
